Just looked on the forum couldn't seem to find it
does some one know where the bolts/screws that hold it on are placed
Plz
Mark
remove the plastic covers in the rear boot wall theyr should be about 10/12 nuts along the floor..getting it off is fine its getting it back on thats a pita
u know i bloody thought i seen some bolts .. got to take the ice install out again .... GGRRRRR
ah gutter m8y
should be 12 now that i think about it 2 on each side then 8 on the rear wall..if it helps get a mate to help with the putting it back on..i found that when i got it lined up when you get maybe half lined up and in position the other half pops out..if that makes sence
No one has mentioned them so far, so I will, there are also 5 or 6 plastic straps that are a stock part of the bumper, underneath the car near the petrol tank, they are screwed/bolted to the chassis with plastic screw/popper thingies. You most likely will have to cut the popper bits from behind to get them out, both the grey one and the yellow one the screws were seized solid and just chewed up in a screw driver (20 year old plastic) and I had to get a pair of snips, snip the back of the popper off, then they just fall away from the chassis.
....and dont forget the number plate wiring - disconnect from the loom in the boot and take it off with the bumper. And a large crosshead screw in the wheelarch going up into the very top corner of the bumper.
