fitting diff with poly bushes
Hi,
Has anyone else found it hard to bolt the diff to the subframe after fitting Energy suspension bushes. I can't get the diff to align with the bolt holes.(bracket end) For 2 nights now trying different ways. The bushes sit against the diff on the rear. I'm guessing this is the problem as it makes the diff sit about 3-5mm to far forward to allow me to bolt the bracket to the subframe. Really starting to piss me off as its not an easy job getting it in place and messing around with it.
Any ideas? Thanks Dan
Yea tried last night but my phone turns its self off as soon as the flash comes on. I'll try later today
You may need to push the cups back a little. iirc the mounting points on the diff actually going into the bushes a little. If you look at the diff you'll see that that the alloy around the bolts is shaped to fit. It's a bugger but you'll probably have to use a hammer to knock the diff in far enough to fit.
