No brakes?
Changed my front studs today,went for a drive and my brake pedal went to the floor i then pumped the pedal and had brakes again but then it would happen again and again also had a bad vibration from the front wheels,i took it to the garage they fixed it and said it had a little bit of crap between the disc and the hub i'm amazed a little bit of muck could cause these problems?
So am I !-more like it had air in the system.......
Wot a nob!-just read that again PROPERLY! LOL!-yes quite possible,too much run out on the discs,did you check when you fitted them?
Thing is im not mechancally minded i should of got some one else to do the job lol i was chuffed when i had finished the job patting myself on the back big time.Had to pay 40 quid to the garage in the end lol.
