Help Needed
Anyone willing to travel to Pontypool/Newport area to help with wiring the TT engine into the 200sx track car???
I know it's a long shot but could do with a hand if anyone good with electrics, I know it's a long shot but really need a hand!!
I have 300 loom so it's just identifying the fuel pump, power feeds etc..
Any help greatly appreciated, some beer tokens and all the tea/bacon sarnies you can eat. Even have a spare room if your travelling a distance and a great local pub 100yds away!!
Newport south wales, 2 1/2 hrs from Derby, take any days really, want to crack but no 100% confident to do the job!
i did wonder what newport u was talking about ...
whats happening this wednesday ...
and what type of help you needing ?
Flying to Italy Wednesday :( for 2 days for work, back Friday.
basically another person to work out the wiring with me, working out the wiring that connects to the 200, rev counter, fuel pump, loom power etc.
ok thats out then ... hhhmmm
see if we can get another person on board
and a better day for it
Hopefully, really would like it going for Japfest!
Trying to get the Z done as well for the show, but that's a Jimmer build and turbo change which isn't so bad!
Not going GT35's as to much lag, looked to compound charge but not enough engine bay room!
Going for a pair of these I think
T3/T4 TURBO CHARGER T04E 0.50 A/R * 3" Inlet Diameter * 2" Outlet Diameter * Hybrid Journal Bearing * T3 Flange * Oil Cooling * 450 HP Capable * Compressor Wheel 0.50 A/R Cold Side * Ind: 52.76 mm * Exd: 75.46 mm * Trim: 48.9 * Turbiner Wheel 0.58 5-Bolt Standard Hot Side * Ind: 57.75 mm * Exd: 73.35 mm * Trim: 61.9 * 25-35 PSI Peak Power Performance Output Capability
is that 25>35psi 450 for the pair or each ... has its very sim specs to what i just got just think your EXd is a little bigger .
not far off
good for 330 each
Turbine
Ind Whl .... Dia Exd ....Whl Dia Trim A/R
46.5mm .....60.1mm .........60.... 0.60
COMPRESSOR
Whl Dia .......Trim A/R
53.0mm .......62 0.64
Cool, I have to beat the 503bhp I had last time but want driveability so the GT35's were out, good thing is these are £170 cheaper each as well!!!!
on what size LT engine .... 2.0>2.5 ?
2.0 so hope they could manage 300-350 at least if I'm feeling brave :yes:
cool nice powers i'm looking for around 450ish (wheels ) and a good fast spool
like u said dont want to much lag and dont want the tubs to kick in around 5k lol
Waiting on final sizes to make sure they will fit before ordering......using these to compare!
