compression test results
Following on from my previous post i have done a compression test this morning and pleased to say all 6 are at 170 or a couple either side but non of them are down on compression.
However i still have the poor starting problem and all 6 plugs are black surgesting over fueling.
Anyone point me in the right direction on what could be causing my poor starting?
No boost leaks
new engine wiring loom
all injectors tested and all have 12 ohm resistance
new injector seals
please help its doning my head in!
No boost leaks
new injector seals
Well thats good news, did you ever do a basic ECU diagnostic to see if any errors like ECU water temp sensor are coming up?
smithy
smithy
Whats your fuel pressure like.......i had a duff fpr on a v6 calibra once and you had to turn it over quite a bit to get pressure up, changed the fpr and it would fire first flick after that.
Egr valve still on it?
nope been blanked off
maf playing up?
I have had problems with my maf but i cleaned it and sprayed it with wd40 and the car has been fine since. would it stop the car starting?
smithy
yep its coming up code 55
is there a way of testing it?
maf playing up?
smithy
As far as I'm aware its not the right thing to do... you shouldn't clean the MAF with anything that leaves a residue... (non-residue spray on electrical contact cleaner, only)
that will only cause problems...
need to see what Jeff says about doing this....
How's your timing? can be a major cause of difficult starting.
Also, is it always from cold? might be worth checking if the auxiliary air device is opening, you could try disconnecting the pipework prior to it and allowing a tad of air in.
Worth a shot.
yeah my timing is good had a conzult on it a few weeks ago and was at 15tdc. and yes only when its cold and i may be being dumb here but dont know what you mean by auxiliary air device? is this the AAV unit?
Yes the aav at the back of the engine pass side.
I'd get your timing checked with a gun as well just to be sure. Vodkashots timing was at 30 but conzult said it was at 15.
Not sure on the procedure for checking the fpr on a zed, some cars have a schrader valve on the injector rail you can connect a pressure gauge to (most vauxhalls have) to measure the fuel pressure.
I had this once, caused by duff water temp sensor. Ecu over fuels to compensate, also caused the aircon elec fan to come on
