I think you need an adapter housing and there's a bit to do with electronics
One of the techies will come along soon and give you a parts list or do a search
Yes it does. You will have to grind the bell housing though. And you'll need to space the starter motor iirc. Like Tony says, do a search. All the info you need is there.
yes you can but like daffy says you will need to grind the inner part of the bellhousing unless you use a n/a flywheel which aint practical for a turbo unless you use a high performance clutch kit.and i believe that you can get a spacer plate to move the starter to the correct position
