ok what a day first the drivers door wouldn`t open so i had to rib the door card of the door with it shut then broke the catch at the end of the key barrel there is an afermarket alarm fitted and i think that was causing the problem and then went to sort the drivers window out which was also not working so i replaced the switches and the relay box and the window went down about 4 inches then stopped again it seemed very tight so then i put a direct feed to the motor and nothing only sparks coming from were i was connecting the feed from.
so the next question is how to replace the motor is it a bitch of a job,and what should i do about the locking
ย
cheers trev
