PCV Connections
Hi all,
As ive changed all my pipe work...by memory im guessing the PCV pipe coming off the cam cover needs to connect to this pipe in the pic?
Am i correct? Also do i need anyother connectors to make this pipework work?
Thanks Dan
The PCV pipe should connect to the old hard plastic pipe that was under the one you've arrowed.
Thanks for your reply. That pipe has been replaced with a larger diameter metal pipe as in the pic. Ill have to try and adapt the pipe leading to the turbo instead.
Thinking of using these
http://www.demon-tweeks.co.uk/Search.do?method=delegate&n=1773&p=243525&s=hose+take+off
or
http://www.demon-tweeks.co.uk/Search.do?method=delegate&n=1661&p=243546&s=hose+take+off
or
Your welcome mate, for piece of mind I'd go for the second option.
