protoj ·
hi m8,ive been told that you might be able to help me with ur expertise on zeds?
would you mind possibly having a look at 1 of my post below,its the 1 asking for help!(big probs)
any help/ideas or even guesses would be welcome to myself and another guy with the same probs.
so far we are looking at changing our induction kits/checking for leaks..
we have allready had recircs checked/mine has been on a consult machine,which 02 sensors were bad(now replaced)but still have the problem
please help if you can it would be much appreciated.ive asked others who are in the no,but so far have been not much help
thankyou m8 jaylox
[This message has been edited by jaylox (edited 24-06-2002).]
