Speed sensor
hi right i have currently coverting my z32 n/a from auto to manual all i need to now is (im using a tt g/box-n/a flywheel/clutch) i need to now what speed sensor to use can i use the one from my auto box ?, i do have a few speed sensor that i bought in a job lot of z bits i have noticed that the drives are colourered , blue or green does that denote anything .
Not sure if your n/a clutch will fit to a TT box. But if it does it won't last long
ย
gear box ratios are the same ,all thats different is turbo uses a bigger fly wheel so wheres the problem .:offtopic:
No mate, you can't use the auto speed sensor, it's different, they are coloured, but off the top of my head, all I can remember, is that the auto one is green.... I'm not sure whether the actual sensor is different or just the cog on the end is... (sorry, not much help)
You will need a non turbo manual sensor as your non turbo diff is a different ration, the auto and manual sensors are very different, the manual one been much longer, manual ones can be hard to find used as most people keep manual gearboxes intact, and are expensive new (around ยฃ120+ )
ย
I can do you a swap for a non turbo manual sensor for your twin turbo manual sensor if you want.
ย
Non turbo clutch will work fine whether you fit a non turbo or twin turbo flywheel.
ย
ย
Jeff TT
Edited by JeffTT
hi yes i would like to do that cheers
ย
Ok drop me an e-mail jeff@zedworld.co.uk with your details and will contact you tomorrow.
ย
ย
Jeff
