power steering
Hey all... i fitted some hids yesterday.. and all is well.. look good. i see more of the road etc and would deffo reckomend them to people who haven't already got them... however i may have touched or locked something i shouldn't as my power steering keeps stopping intermittently along with my speedo ? only started since being under the front fitting the hid kit.... any ideas what I've done.?
Most likely a coincidence, however there is a small solenoid on the end of the steering rack ( drivers side ) there is connector on the cable that is quite prone to the elements, try cleaning this out with some WD40 or similar, a bad connection here will cause the exact symptoms you have, unfortunately so will a dodgy speedo, delimiter, speedo sensor/ cable / connection.
Jeff
Cheers Jeff.. if it doesn't work ill pop up to see you in the new year...
Yes no problem.
Jeff
