Help im stuck
Im after some ideas if possible?
Ok i want to plumb a balance tube to even out the pressure before the throttle bodies as ive installed an FMIC.
My problem is where to install it as i have no room on the pipe work close to the throttle bodies.
I was looking into using alloy adaptors that you screw in to the silicone pipework but i cant even do that.
Old pics here but gives you an idea.
i don't get it, you have a balance bar to equalize it after the throttle bodies. are there any gains to be had by balancing them before?
If you really want to do it, then move the dump valves to the usual place being the outer pipes, then you can fit your balance pipe on the inner pipes.
smithy
Hi smithy,
I've had the take offs removed and welded up when I had the pipes powder coated. Anyother ideas?
Thanks Dan
