drivers door not opening
ok the drivers door is not opening from the inside or outside and the electrics on the door not working also would it be fuse or is it going to be nightmare to sort because the door is not opening its going to be a pain to get the door panel off
cheers trev
cheers trev
does the passenger side open? and can you not open it from the keylock and door handle?
passenger side is ok and the drivers side no nothing works
ok its seems the lock itself is jammed i have removed the switches and had a look and it seems all connected
Inhad this problem before. The srew inside is missing its connecting to the handle from inside. Take of plastic bit from the handle inside try to open than by pulling metal wire inside which connected to handle.
