- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
any one help please put a bulb in the courtesy light got it slightly twisted then the radio went off and the courtesy light indicator on the dash now glows dim even with the door shut
if u open the door the clock goes off and the 2 map lights start acting up the courtesey light now not working
found this post mine exacty the same any help please
It all started when my main interior light blew. When changing it there was a spark.i put a new bulb in and it still doesn't work. I checked the fuse and all was ok. That is not the confusing part..... now when i get in the car the light that warns you the doors are open stays on and the digi clock goes off. When i switch the map lights the clock comes on and the light on the dash goes off. Also my stereo now doesn't work. As i said i checked all the fuses and they are ok. Have i damaged a relay somwhere or could i have caused an earthing fault. I cant work it out because the power is at every instrument but it then seems to fade away in about 5 secs. Any idea's?????
Edited by spritley56
