ok so my car is overfueling guzzling fuel like it's going out of fashion. No check engine light but ecu reads code 12 air flow meter circuit??. Things I've done....changed spark plugs and fuel filter. Problem started after I replaced the very old tatty crumpled cone air filter. When I say bad...it was that blocked that the engine had almost crushed it inwards trying to draw air in. I'm guessing that the engine over fueled to compensate for lack of air?? I don't know as I'm new to this. I did remove and clean the MAS with proper cleaner for the job and re installed. At first car wouldn't start and when it did it was rough but then I realised I hadn't connected the sensor, so plugged that in and running smooth again but still overfueling. Someone said I need to get it tuned... I just need help please:scooter:
