Me again.
So I have two questions:
RobHowl ·
first of all does this sound ok with you tech guys?
ive been out in the car testing out my new boost gauge and boost controller.
i set my controller to 0.60 and run the car my new gauge said 10 psi.
i then set the high boost to 1.0 and run the car it hit 14 psi
now for the guys interested in stock figures
14 psi stock was 10 psi on new gauge
on 14 psi on the new gauge the stock was just stuck at 14 psi
well this proved this proved to me how shit the stock gauge is!
