Fitting the Fuel Pump ECU on Saturday
Just wondering if there's anything to watch out for, do i need to have the battery disconnected before i unplug the old one? or do i need to do something with the main ecu after i've fitted the new one?
Any advice would be helpful...
Very straight forward swap, simply unplug the old one and remove it ( 2 x 10mm fixings) and replace and connect the new one, no need to disconnect the battery or reset the engine ecu.
Jeff TT
Jeff TT
excellent Jeff, thanks. just to check It is under the passenger rear quarter interior panel?
Oh, so that's the square thing that looks a bit like a bomb?
Think that'll be the thing. there's an abs ecu i think too, but not sure which is on which side, don't know if it differs to left or right hand drive.
I posted the schematic in your previous thread... if you are sitting in the back seat it's on your left, doesnt change between LHD and RHD.
Yeah I remember i just couldn't find it for some reason in my previous threads. found it now though thanks again.
