Targa drain sorted
Spent most of the morning sorting out my passenger side targa drain, and decided to change the pipe completely rather than try to stretch it.i put a small steel sleeve in the end so I could attach the rubber piece that goes through the body with a small hose clip so it wont come off again.
Biggest headache was the corroded connectors where water had been running on them, a couple broke and needed re-wiring which was a pain as there isnt a lot of room, but at least they should stay nice and dry now. :)
Id keep an eye on that, if it corrodes it will end up just breaking apart and you will end up with the same problem, may have been a better option to use a small plastic tube instead.
Hi Dill the dog, any chance i could persuade you to help me check and do mine ????
Used a piece of aircraft grade stainless steel tube I had knocking about ;)
Hi sayers, would give you a hand one of the days, even though it was a p.i.t.a, lol.Wednesfields Brum way isnt it?.
Have got to delve back in tomorrow to tidy the wiring up a bit better as I ran out of time today as had stuff to do.
Dill i live by junction 2 of the M54 so not far from you at all,
have got stuff going on at the mo,but may be free the weekend after next, will let you know.
thanks, im in no rush at all, the car is sorn for the winter but it is a job i have on the must do list., likewise if you need help ill lend you a hand just let me know
ok mate, will be in touch
