where to find sills
Just a quick one guys im after a complete offside outer sill, dose anyone know where to get some from and a ruff idea of price thanks
yea - as said, genuine only so MJP.
there not cheap - around £200 per side IIRC.
plus if you need the rear section (which you will LOL!) then you need to allow for that too - non genuine repair panels are around £45 per side for the rear lower sill repair
Those prices are about right Paul yeah, except the £200 is inc VAT approx and the £45 is exc VAT approx, from memory at least, but it's a good 6 months or more since I did mine so the prices may have changed ;)
i need from the wing to the rear wheel, and dose anyone know where abouts in the door shut the pannel goes to?
Wing to the rear wheel is two pieces. Look closely at your sills, you'll see a vertical line/join about 2/3rds of the way down the door space in the sill. The front section literally goes from under the bottom of your wing, to that vertical line, the rear section goes from there to the rear arch, then up just past the swage line.
EDIT: Just for extra info, the front part is your sill, the rear part is the 'sill return'
