protoj ·
going cheep, not mine.
http://www.ebay.co.uk/itm/fits-300zx-3-piece-split-rims-wheels-/130601184185?pt=UK_CarParts_Acc_Wheels_tyres_Rims_Car_Wheels_ET&hash=item1e686febb9#ht_500wt_1287
