Water leak into passenger footwell
Hi All
My Z has been pretty well bulletproof for the past 7 years but I went to use it yesterday and as I started it, I noticed about half a cup of water on the passenger side mat (fresh cuz it was sat on top and hadn't started to soak in). Hoping it might be a screen wash pipe disconnected or something, I decided to look later. Drove a couple of miles to the shops where on restarting the engine, it dumped another half a cupful of water on the mat. Smelled radiator like this time. Drove home and checked - tiny amount of radiatior water loss but also, the radiator wasn't pressurised like it would normally be.
Does anyone have any idea what the most likely problem is and how to get at it? I'm guessing it's behind the dash - OMG!!! Also, what it maight cost and where to take it in Wiltshire? Local Nissan is obvious but I don't think they see (m)any 300ZXs and I guess will cost a bomb.
All ideas gratefully received.
PS It's a NA vert.
Paul
Edited by PaulZ
Heater matrix behind the dash, it's high enough that after some of the water has come out of the engine you won't notice as much missing from your engine and would also de-pressurise the system.
yeah mate.. common fault... heater matrix and or the pipes to it...
crap job to do... i think there are a number of threads on here about it...
you could disconnect it or replace it, the replacement units are for a different model of Nissan and aren't too expensive... around £40 if i remember correctly (and you mat also have to get new hoses).
either way its a pain to do..... so a search in the FAQ section .....
Nice one medallion man, I'm replacing the heater matrix in the grey one with the one from the yellow one today, although the dash is out on both right now, so much easier ;)
Mmm ....... been reading around. The leak being down the side of the centre console and the smell seems to be a common factor and points to the heater matrix (or pipes). Sod it ......
Thanks guys
before you jump to the worst, the air con drain pipe is on the passanger side and it was that on mine. Also check the targa drain pipe is flowing ok.
Thanks Vijay, but aircon not gassed for many years and its a convertible ..... nice thought though.
Ta
Paul
Zedworld prices range from £310-£360 if their website prices are up to date
The parts needing removed are picured below (from zedworld website) and as stated by others, its a bit of a bugger!
Just to advise: the above is using a Genuine Nissan matrix unit which comes with new copper pipes, foam insulator and water valve, using non Nissan part is less expensive.
Jeff TT
i did it without removing the steering wheel but removing the seat instead, allowed me to lay in the footwell for better access
  • 4 months later...
Jeff replaced the matrix for me earlier in the week - top job.
Top convertable you have there, was a pleasure to work on.
Jeff
Hi
I have water in the passenger footwell but no drop in the radiator any ideas guys
Paul
Sounds like it's your pass side targa drain plug. It may be blocked or come out of the wing holder. Have a look in the FAQ section, there's a write up in there that tells you how to sort it.
Hi Thanks
Sorry bit of a noob on here
Your welcome mate. Had this problem on mine, so was one of the first jobs I did.
