October 30, 201114 yr this is the rear near side antiroll bar. is there a bush kit i can get for this? dosent look right at all to me many many thanks
October 30, 201114 yr Yes mate thats your rear droplinks, you can either get oem from MJP or upgraded adjustables. I've got whiteline ones with poly bushes. They just unbolt, so easy to replace. HTH
October 30, 201114 yr Several choices: 1. Just the bushes in OEM rubber - I'll check a price in the morning, but around £2 per bush at a guess 2. Just the bushes in black urethane - general purpose bush at £1.38 + VAT each 3. Aftermarket end link assemblies - pins, washers, bushes - at £17.95 + VAT a pair. Just check length required - I have three different lengths available.
October 30, 201114 yr Wow they've come down a bit Mike? Weren't the rear drop links about £50 a side earlier this year?
October 30, 201114 yr OEM drop links still run out at more than £50 a side - these are aftermarket versions. Not identical, but do the same job.
October 30, 201114 yr Author Several choices: 1. Just the bushes in OEM rubber - I'll check a price in the morning, but around £2 per bush at a guess 2. Just the bushes in black urethane - general purpose bush at £1.38 + VAT each 3. Aftermarket end link assemblies - pins, washers, bushes - at £17.95 + VAT a pair. Just check length required - I have three different lengths available. ill go for just the bushes please, and its four ide be needing by the look of it, could you price me on them posted please :-) many thanks again
many many thanks
