Been busy again.....window rattles sorted
Been busy again today and sorted my rattling windows out with new pins and slider rollers.i took the door trim panel off to do the drivers side, as I removed the control box thingy for the electric windows and re-soldered the loosr connection on the circuit board whilst I was at it.also removed the window guide to clean all the accumulated crap out of the groove and lubed it so the window slides easily.
The passenger side was easier, I just removed the top seatbelt mount and the top two pieces of trim and unscrewed the window guide pin with a pair of long-nosed pliers,replaced the new guide pin and roller in the same way and put everthing back on.had to put a new nut on the top of the guide as it was missing and obviously not helping the rattle situation!.only took about 10 mins to do passenger side so was well chuffed.
So now both windows slider up and down nicely with no rattles and sit nice and tight against the rubber when closed so less wind noise as well, and the drivers side one works when I want it to, for the sake of a bit of solder so happy days! :)
Starting to get attached to the old girl now shes coming on ;)
Well done mate,
It is always rewarding when you get something fixed on your Zed.
I have the same problem and hope to fix it during the winter.
Where did you get your new bits from?
Well done mate,
Got them from my local nissan dealer, roughly £15 for both sides.have got the part numbers if you want them.
Window slider(pin and roller) 80332-46P00
Cover(white plastic cap that fits on the roller) 80392-30P01
The cover is important as the slider roller will be a loose fit in the guide rail without it.when the new slider is fitted back into the guide rail it is quite a tight fit and you have to use a bit of pressure to got it in, but once it is its a perfect fit and the difference it makes to the car is well worth the effort :)
