new problems?
Well after working on my zed for past couple of weeks im now a bit stuck. I have put a new engine wiring loom in done a water by pass new plenum gasket cleaned all the injector connectors and all other plugs i can get at.
Anyway i now have lumpy idle and the zed does not like to start when its cold? It was starting fine before i changed the loom but had a miss fire which has now gone.
Any ideas whats causing it not to start? Also it seems to be using a lot more fuel than it used to??
Has a s2 ptu
is a 92 tt
new engine loom
had temp sensor 6 months ago
Code 55 on conzult
Do these zeds suffer from fuel pumps?
fuel line on the right way ?
Ummm i wonder lol ill check tomorrow and i did cheak all the injectors and they gave me 12 ohm restistance on each one.
