Hi Mark,
I can't speak of the ebay pulley set you've linked to above but having sold lightened pulley sets through my business in the past I can tell you that if any of the pulleys (but in particular the crank pulley) isn't completely balanced at the production stage then it "could" lead to serious and expensive engine problems. I used a UK based company for the production of these and they worked to an extremely tight tollerance which meant that the finished product was near enough 100% true balanced.
I have seen an awful lot of these kits come over from China and the quality was abominable. Sharp edges which will shred the belts, uneven grooves which could make the belts skip off the pulley and most of them were very unbalanced.
Having said all the above, I do know that a number of members on here have purchased ebay pulley kits of Chinese origin and have had no problems at all. For the price quoted I'd say it's very competitively priced seeing as how my complete kits used to cost nearer £210. However you get what you pay for and my suggestion is that should you buy these through ebay that you check them very carefully before you install them on the car. If anything doesn't look right send them back and ask for a refund. It is not worth ruining your engine courtesy of a set of cheap pulleys. I also suggest you use new belts (either genuine Nissan or Dayco belts).
Regards,
Dan
thanks for the info ...
on another note i have one of your 555 ecu chip
can you tell me with in the programming dose it still have the speed limit
and the Max RPM set
Mark
and the Max RPM set
Mark
No problem.
The 555 chip will not be speed limited but I'd have to ask Eric (Lymon on here) what the max RPM is. Will get back to you.
Regards,
Dan
If you are looking for a lightened pulley set i would recommend AMS. Good value and as far as i'm concerned a good manufacturer
is that ams performance car parts ... as checked there and no nissan 300 stuff
Ams motorsports.....
http://www.amsmotorsports.com/shop/ind/
Also available (often cheaper) from Z1 motorsports
