EGR delete??
  • Replies 38
  • Views 2.6k
they dont do anything else and normally come off easier than expected due to being threaded into the alloy of the lower plenum. trust me try it ;-)
Yep, very very much doubt you will snap them, man up :hammer: :)
Ok there is no way i can get that off the back. I cant even get a spanner on them. Ive removed all the vacuum pipework now. Is there any way i can just leave whats there and it'll all be fine?
well cut nothing yet. I was intending on cutting the bits that go under the plenum off along their length and block up the holes on the plenum. Do i need to block off the pipes ive cut or will the whole thing be inactive now?
really you need to block the pipe from the n/s exhaust manifold but as long as the egr valve is good and the vacumn pipe is disconnected you can leave it there. but will need to block off the plenum
I cant even see it in the manifold, Can i not just leave that there. I assume that the egr opens up to accept gasses from the exhaust then flows it through when it needs it
