EGR delete??
  • Replies 38
  • Views 3.3k
they dont do anything else and normally come off easier than expected due to being threaded into the alloy of the lower plenum. trust me try it ;-)
Yep, very very much doubt you will snap them, man up :hammer: :)
Ok there is no way i can get that off the back. I cant even get a spanner on them. Ive removed all the vacuum pipework now. Is there any way i can just leave whats there and it'll all be fine?
well cut nothing yet. I was intending on cutting the bits that go under the plenum off along their length and block up the holes on the plenum. Do i need to block off the pipes ive cut or will the whole thing be inactive now?
really you need to block the pipe from the n/s exhaust manifold but as long as the egr valve is good and the vacumn pipe is disconnected you can leave it there. but will need to block off the plenum
I cant even see it in the manifold, Can i not just leave that there. I assume that the egr opens up to accept gasses from the exhaust then flows it through when it needs it
you can see it if you remove the battery but yes you can leave it if you must !
