93Z n/a sometimes will not start,just dash lights.Alarm bad?
Sometimes when I turn ignition key, I get dash lights, but car does nothing. Is the alarm going bad? How do I bypass alarm?
It could be the immobiliser or there is a possibility that you have a bad earth on the battery/bodywork. Do the lights go out when you turn the try to start the engine ?
automatic or manual ?
there's a relais in the fender that controls the starter...that might be the culprit.
-Eric
The lights do not go out. It just does not start.
The car is manual. Where is the relais in the fender?
-Eric
I'm not sure in which fender the starter-relay is for a RHD-car (for LHD it is in the fender at drivers side)
http://www.300zx.co.uk/cgi-bin/m anual.cgi?list=el&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=109&design=default&total=133
Do you normally have to depress the clutch to start the car ? because then the little switch on top of the clutchpedal can also be the cause of your problem..
[This message has been edited by lymon (edited 23-05-2002).]
I had this problem and it turned out to be the Auto start inhibitor switch.
I you have an Auto, try moving the lever through the gears next time it happens.
Might just need adjusting.
