its kind of running!!
Well i took my zed off the road 2 months ago so that i could change the plenum, plenum by pass, injector plugs, coil plugs, rocker cover gaskets and few other jobs. Anyway i have just finished putting it back together and turned the key and as expected its not running right. It runs, just, but back fires. I have not reved it as i dont want to break it. Im guessing i have a coil plug on the wrong coil or something? i numbered all the injectors up so i think there right.
Anyone know what i have more than likely done wrong?
Oh i have not set the tps correct yet as i need to order a conzult cable and disk would this cause it not to idle and missfire?
any help would be much appricated
not the tps will not make that much differance. You also cannot really go wrong the the connectors because the brance off like a tree if you know what i mean.
Have you checked and tighten all the vacume pipe up??
i think i have all the pipes connected and in the right place. I was a bit fed up with it after being there all day so ill try again tuesday!
Oh would you know if the det sensor wire that goes to the ecu is simular to an aerial wire. What i meanis it has the earth wire around the main wire? i dont have a det plug on mine at all
ive got the datascan/cable stuff if u wanna meet up n set it up. lemmie know, not to far from u
i may well take you up on that offer once it is running again. :thumbup1:
