trying to change the power steering belt
got the adjuster nuut undone but cant get the actual pump to move to get the belt off im working from under the car isthis the wrong way to go about it asm getting frustrated now at what should be a easy job any advice or diagrams will be helpfull please lads
Have you undone the bolt that goes through the pulley hole? You may also need to tap it round with a rubber mallet.
no is that the pulley where the belt goes round and which way does the pump go is it towards the centre of the car
If you line one of the holes up in the pully around the one oclock position you,ll see a bolt head which is either 14mm or 17mm , i cant remember which , slacken that and the pump should now move , just don,t forget to re-tighten it once the new belts on !! HTH
If you've already done the adjuster, you may need to pull on the pump with the old belt, they can be a real **** to move if they haven't been moved for a long time, in fact, mine has moved several times over the last few months, and it was still a **** to move last time I did it the other day!
gave it up as a bad job just couldnt move the pump will leave it for someone else must admit defeat on this one lads
