Oil Temps & Pressures
ok after an engine fail i have fitted a Oil Temp and Pressure gauges
Oil using right now is valvoline 10w40
now what i'm wondering is what is the Max Temp the oil should get to when booting it .. as its peaking out at 105c
normal temp seems to be around 85>90c
but the other problem i'm getting is when it is up to temp
and when the engine drops back to idle or gets around 700/800rpm when pulling off the Pressure will drop to about 10psi and set my gauge alarm off ..
but normaly around 30psi ish
but the gauge on the car dosnt drop below 1/4way but very slow
my gauge is all most Instent movement when throtteling
so the Q is
is my Normal temp OK
is my Max Temp OK
does my Oil Pressure sound ok
could i use my auto oil cooler as its bigger than my oil engine cooler or even both ?
Thanks again
Mark
My max temps reach 105ish
As for the guage alarm I have the same thing now I have adjusted the idle to 750/850rpm bloody annoying :hammer:
yeah me to and its better but still kinda does it when at high temps
just wondering if oil is to thin at 90c+
Would a Diffrent grade of oil be better for keeping Pressure higher and temps a little lower ?
if so what grade would i need
THanks again
Mark
