Light weight pulley
I have a spare alloy crank pulley and all belts of the engine i got from Uno, i have removed it but never fitted to my Uk.
Does it make much of a difference?. sure its far lighter, but can it make a noticeable difference,
what are the benefits.
A few pounds lighter than oem, but unless you have other lightened mods, like prop/flywheel/water pump pulley etc, you probably wont notice much difference on its own although saving a few pounds off through the crank can only be a good thing.
I have lightened one piece prop/flywheel, water pump pulley and lightened crank pulley and on my NA its definitley more spritely than it was before, but it was also an auto before, so going manual has helped.
Mikey noticed a big difference when he fitted his, but then as Graham says, Mikey had a lightened flywheel already in place, so the two combined ...... that said, it should make quite a bit of different really, because it's way less to spool up.
hiya mate i put a full set of pulleys on mine an it seemed to rev faster wen you blip the throttle. but cant say it made much difference wen driving. till i got a lighter flywheel
