Speedo question...
Real quick on this...
Does a 110mph speedo de-restrict a Jap import or do I need the 160 / 180 type?
(I think 110mph id the 180K/m type maybe?)
Steve
A set of clocks from a UK car help with the speed restriction, but ultimately you want to end up with a chipped ECU, which will raise the restricted rev limit.
180mph on the UK clocks 180km on the jap. To de restrict on jap clocks you will need a km to mph convertor, it tricks the ecu into thinking its going slower than it is, but can also affect power steering/hicas.
3 main ways
1) chipped ecu
2) speed converter
3) UK speedo
as groover says you need to fool the ecu by changing speed signal or remove the limiter via a chipped ecu
