aftermarket bumber - plastic under car/engine
Hi
Just wondering if anyone else had problems fitting the plastic under the car/engine when installed aftermarket bumber and fenders? I've got a blade front and viper fenders.
Yes. I had a bumper fitted and sprayed and didn't know there was a problem until a loud grating noise every time I put my foot down. Turned out the front undertray section wasn't secured to the bumper and the airflow was forcing it to rub against the road! I removed what was left of it, not sure if there is a reliable way to install it so may or may not bother with a replacement..
H
I made a new centre section out of a sheet of aluminium going from the main suspension X member to the bumper , basically replacing the original plastic one and the wing splash shields that extend to the lower corners i extended them further to reach the bumper and new aluminium shield using some offcuts old splash shields i had :thumbup: HTH
