Boost Settings
Got my Self a Blits spec-R Controller
just wanted some info on whats the
Max Boost ( Play time )
Safe Boost ( Normal Driving )
Min Boost ( Wet Weather )
i can run with my car
FMIC AutoBarn
Full Silicone Pipes
555 Injectors
Stock Auto Turbos
AndyP Devlin 555 chip ( Agressive Fueling ) so i have been told
does seem better than my DTa555
i got the Jist of how to program the controller on the 0>100% to slect PSI boost .. and what the gain does
Mark
9psi wet.
12 psi daily
14 psi play time
i read some where on here with the bigger injectors and chip i could run 16psi there abouts ... turbos are maxed around 18/19psi right ?
i run mine a little different tho.
6psi wet
10 psi daily
12-14 psi for play
11.5 psi for drift. with lowered SET but higher GAIN for better spoolup and response.
ok thats intresting
so do u have the gain on 100% then ( drift mode )
and why lower psi ?
Helll no 100% on my tubs is over 25psi
my gain varys from 5% to about 32% depending on how much boost i want, but if i want it to kick in hard, but not boost to fast it will be like this..
SET 20% GAIN 18% boost will be about 12 psi and fast spike
SET 30% GAIN 5% boost will be about 13 psi and slower to get there....
but each car is different, me and AlanZ have the same controller, but set up very differently to achieve similar boost settings...
trail and error i guess. good luck.
Higher PSI is not a problem as long as you know for sure fueling is spot on with the correct mixture throughout the boost range, otherwise det will destroy a piston, or 2.
smithy
as for why lower PSI for drift, just how i prefer it as how i drive its more suited to me so i can regulate throttle balance in 2nd and 3rd gear corners, too much boost and it just wants to hit the redline/ rev limiter too quickly, and thats not what i like, as i come from an N/A drift background.
any other person got more input on this ?
thanks
Mark
thanks
Mark
From my experience keep the actuator boost solenoids connected which has triple benefits, first you keep the a level of safety if detonation occurs, and full boost is harnessed when the engine is cold.
The third benefit is the boost controller duty level will be lower and this gives greater range for adjustment and lower solenoid response time which is helpful when setting up.
Boost controllers are universal so settings will not be the same from one car to the next.
Jeff TT
