Experts needed ?
Cutting a long story short i fitted an oil line from the rear of the oil tree to use for the oil pressure and temp sensor for my digi dash. Only untill now when im getting to the stages of trying to fit the gearbox ive noticed that the oil line might be in the way?
What do you think? Does the starter motor butt up agaist the block? Also the sandwich plate looks close as well.
Cheers Dan
looks like there is loads of room the starter motor is higher than those two pipes
yeah still looks like loads of room as the starter motor sits in tight to the g/box so i wouldnt see it being that far forward
Ok cheers the only reason i asked was my starter looks like the lug sticks futher out from where the gearbox meets the block. If it does im hoping the pipe isnt in the way.
Edited by GIBSTER-TT
yeah i see what you mean that braided hose you have on looks like it can move slightly? should be able to get it to fit then :)
