protoj ·
Had my garage broken into. They took my specialized hardrock sport plus my daughters bike :censored::censored::censored:
Luckily the Z was not in the garage. Going to beef up all the security in general
and may even cover the pit as a kind of booby trap if they manage to get in again. They walked past everything else in the garage to take the bikes.
Has wound me up as keep waking up now and having to check. Never had a break in before.
