What kinda power???
before I get her Dyno'd was wondering what kinda power I should expect from this set up, I know id have more if I went on to 555 injectors and when funds allow i wil but for now what do you reckon
(spec taken from my rides)
Apexi AVCR Boost Controller
Twin HKS Air filter kit
Series 2 PTU & Harness
AutoBahn Front Mount Intercooler
SS High flow manifolds
Japspeed Divorced Downpipes
Japspeed Decats
Custom Cat back Exhaust system
Koyo Rad
JWT Chipped Manual ECU
Turbo technics stage 2 hybrid turbos
Underdrive crank Pully with new Belts
Fully rebuilt ported & polished heads
Ported & Polished inlet manifolds
Forged bottom end with oversized pistons & Conrods
RPS Streetmax Clutch
Fidenza Lightweight Flywheel
Aircon Removed
Hicas Removed
AIV's Removed
EGR Removed
Cheers Craig
Japspeed Decats
Koyo Rad
Aircon Removed
Hicas Removed
AIV's Removed
EGR Removed
Cheers Craig
PS prize for the closest guess
What boost are you thinking of running? Whats stage 2? is it standard size turbos with a 360 degree thrust bearing?
early 400 i would think at the wheels or very close.
Have you lightend anything? ie, hicas, air con. Yep the injectors should make a few more horses. What is the boost your running.
Sounds great even before a dyno.:punk:
I was going to ask the same thing. The 2 most relevant details to the power output.
Tbh I'm not sure what stage 2 means I will have to do some research and same again I haven't set the avcr up yet so I don't know what boost I can go too safely.
Yeah loads gone
Hicas
Aircon
Egr
Aiv
All deleted
