Oil pressure
What should the oil pressure usually be?
Mine keeps changing, i know the guages not very good but i dont have the money to buy a different one.
Its usally between 0 and the first bar, then after a few miles it will go up and maybe later on it will drop down again.
Im pretty sure i have no oil leaks in the engine anywhere.
Probably just a faulty guage or sender???
It will change with oil Temperature and rpm.
The Senders reads pressure through a small venturi which gets blocked over time....but also the stock gauge is very innaccurate/unreliable.
