another air leak?
right stripped the plenum off again, to sort a water pipe out that came off. coincidentally the std clamps don't work too well on silicon hoses lol. found a few t clamps so sorted that
but their is another air leak i found just before i stripped it back, its down the rear of the engine where the egr is....? right i've replaced the hose on the egr, its not that, when i took it apart i check the plenum gasket( not that)
i cant see any other air pipes down there what could it be its really confusing me,
anyone know of anything else down their could cause a leak? can hear it when driving (especially as the turbos spoil up) did a boost test using the space saver so me psi and its defo round the egr.
i had a similar thought, they tend to leave a residue behind and im not sure what it would do.
i was thinking if you sprayed it round the area, during a boost test it might help find the leak?
pulled the plenum again, (this time i bypassed the water pipes,) actually easier then i thought it would be
egr is still on the car although i did find the exhaust manifold bung, just cant get to it with the engine in lol.
can happily tell you its fixed!!!! just took it for a test run and its just like it was before. :clap:
the air leak was a crack in the rocker cover??!! swapped it for a spare cover and all fixed yay!!:thumbup::clap:
I just found my ones as well... well I think i did anyway... elbow pipe going back into the rocker cover form the PCV... really loses... going to test it tomorrow...
well done sorted it :clap:
