Managed to have a play around with my Data Scan software today, (once I had finally got it to work)
Would someone be good enough to take a look and pass comment please?
3 out of 4 look OK to me,(but what do I know) Just could not figure out the correct port setting for the 4th. Any ideas?
Thanks in advance, Redwine300
Engine at start up
Engine Warm
Hicas
Port Setting
Looks to be ok but your idle revs are a little high should be around 750. Your AAC should be 15 - 40% at idle, yours is a bit low at 12. Probably just need to adjust your base idle a tad to sort it. Saying all that, I'm by no means an expert so before doing anything I'd wait and see what other say :) (phew, got out of that one! lol)
Your first screen is pointless as the car needs to be up to temp to get the readings your after, like the second screen. TPS needs to be 0.44, then set your base idle wth the aac plug off, bring the idle down to around 700m then plug the aac plug back in ( the one on to of the valve with the base idle screw) the revs will then rise by about 50rpm and the ecu should then take over the base idle.
Jeff will be the man to tell you what the readings should be.
:thumbup:Thanks Steams,Groover.
Appreciate you taking the time to pass on your advice. I will make the changes as you suggest and see what happens.
As you say, maybe Jeff will drop in and help further.:thumbup1:
Still haven't managed to get the A/F feature working mind, anybody had the same problem?
