Rad Bracket with Slight Mod
Just a thank you to the two members that helped me out with this and a plug to boot.
I got the Polished Aftermarket Radiator Bracket from AlanZ and the bespoke 'SLICKTOP' plate from TwinTurboRich, I am going to rivet the plate to the bracket.
Both just roughly offered in place currently as my new radiator will be fitted after JAE character0182.gif
Looks smart mate, you going to put an EL panel behind it???
Not sure if you're being sarky as I do get ribbed for lighting up everything - not sure why sad0049.gif
I could easily do that and do you know I think I will as I am getting some EL panels anyday from HK, to come on with the sidelights methinks happy0071.gif
No wasn't being sarky mate, think it would look cool if lit up, be good for shows etc..
Could you not bond the plate to the bracket? so you can the plate smooth
It would good lit up
Yes that is still an option but thought a couple or rivets or some nice bolt heads, either four or two will look quite nice, not sure on the clearance below or where it will just go, so have to just sit on my hands at the moment jumping0048.gif
