Tyre Pressures
anybody able to confirm the correct tyre pressure for Road use for the following
Front Continental contact SP3 235-45-17
Rear Continental contact SP3 245 - 40- 17
thanks
32 - 34 Front
34 - 36 Rear
Suitable pressure range will be about the above, and the exact pressure will be more down to several variances (tyre make, type of driving and your own preference)
well yesterday went and checked my tire pressure, fronts were both on 54.4 and rears passenger side was 32 drivers side 17?
So someone either didn't realise that 54.4 was way too high for the fronts (actually exceeding its max pressure rating) so quick nip down the garage, i always go by car weight for the correct amount of pressure, so check the door sticker to see how much it is standard.
i went for 32 psi this time though, always seems to give the correct amount of wear across the width of the tyre. im running 245/35/19 Avon ZZ3 front and 265/30/19 Avon zz3's on the rear.
