looks like the one ive got, mine how ever doesnt work with the genuine conzults software (not on about the hacked stuff either) will work with the Conzults trial software though, but you cant adjust things, only monitor and even then only limited capabilities due to it being a trail.
Though ive had loads of success using it with Nissan data scan 1.51
okay as long you have a laptop with a serial interface, If you've only got usb you'd be stuffed
nope, nissan datascan can use the USB connection from serial connection as long as you have the drivers for the usb to serial cable, you then just make sure you select it as com1 and get nissan datascan to connect using com1 (does this by default anyway)
so does that one in the listing not come with the data to do the job then??
says in the listing that it comes with the trial version of conzults
So what would that do. just check everthing? how much is the full version??
The full-fat version of the ConZult "software only" package (for use with 3rd party cables) comes in at 139.00 Euros. Compare that with the complete package (ie, ConZult hardware, cables and software) at 269.00 Euros.
I no longer sell these (due to closure of the business) so you'd have to contact DTA-Motorsport in The Netherlands (hence the above prices in Euros).
Dan
Gonna get one of these of ebay, be a good tool at least just to monitor everything and check things like TPS, o2 Sensors, Injector duty cycles are all correct and how they should be... Conzult trial versions and Nissan Data scan can all be downloaded from web.
Yeah thats all i want it for really just for a little nosey :)
Dan
Thanks for the heads up Dan. I will see what the cable thing does 1st and go from there :)
Hey,
just a note to say that if you do go for this one the total price of the unit is 1p and if it gets lost in post and you try to claim back from the post office they will reimburse you the 1p... they do NOT pay for postage.
yes it has happened to me.... OK yes i know it is the seller you should claim, but if something is wrong with it and you send it back and it gets lost them you only paid 1p for it and that is all they will give you.
