- Replies 32
- Views 1.5k
- Created
- Last Reply
EvoluZion3 9 posts
Stephen 5 posts
njmworsley 4 posts
ianl 2 posts
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Gaddammit now what!!?! The Z just drained a brand new battery in 12 hours :no:
I've always had a small current which results in the battery not being able to start the car if I leave it undriven for 5 or 6 days, but after a normal drive to work it's been fine. Been like this for years.
However after being left stood for a mere 4 days over the weekend, she started ok on Monday morning (a little sluggish to start but that's to be expected), fired up and got me to work no problems - handing a 350Z it's own arse in the process ;)
Anyway on the way back yesterday evening I noticed that the voltage (on my Apexi turbo timer unit) was lower than normal. Normally it will show 14.2v at the start of driving, and level out to 13.7ish after a few minutes. However it never got above 13.6 and dropped to as little as 13.3 - I wasn't using lights and I even took my stereo facia out I was that concerned.
Thinking the battery was starting to fail, or the alternator had packed in, I managed to get it home no problems. Passed a voltometer across the battery and got 12v. Luckily I keep one on standby (this one measured 13.6 volts) so I swapped them over, smeared a bit of Vaseline over the terminals, hooked them up and she was ok (didn't take her for a drive). Locked her up as normal.
Following morning, she wouldn't even start (barely 10v in the battery), so took the standby car to work. First thing I did when I got back this evening was to put a multimeter across the battery and she's losing 25A somewhere!!! :eek:
I started with the fuses in the engine bay behind the steering wheel, and when I remove the 30A IGN / SKID fuse the current immediately drops to 0.6A.
I've not had time to look at any other fuses, I've left the positive off and put her on maintenance charge until I can get to the bottom of it.
Can anyone suggest the next course of action - is it worth putting the IGN / SKID fuse back in and continuing with the footwell fuses, or is this as far as I can get? If so where would I start looking next?
