Fitting braided fuel lines
understand where to put them but what do you do with the vac line that comes off the fuel pressure regulator??
It goes to the prvr solenoid mate, or if you've deleted it, to the plenum.
i know that it goes onto that black thing that looks like 'bent fingers' but with the braided lines that thing is removed!!!!
have a look at my rides section, i have braided hose fitted might help you out a bit buddy. you will be removing your fuel rail if you havent done that already.
That black thing like bent fingers that the pipe connects to (the fuel rail) is a hard line between the FPR and PRVR solenoid. When you remove it connect the fpr directly to the prvr solenoid via silicon tube. Simples :)
Edited by Steams
will take a look what u mean.
perfect steams your the man. :-) worked out just as you said.
No worries mate. If you want to delete the prvr, connect the fpr vac to the plenum side connection that the prvr connects to. Then unplug the solenoid. That and the rest of the prvr can then be ditched :)
Pictures please!!!!!! lol......... just incase I have not done this.....lol
Cheerz dude....
Alz.
