leaky roof :-(
Hi all,
I have a leak on both sides, just above and to the door side of the front seats. Which seals do I need to replace?? - it's dripping from where the trim at the edge of the windscreen neets the roof lining - kind of alongside the sun visors.
Any (relevant) advice appreciated :-)
RobH
Get some rubber treatment slap it on. Give is a few coats over a few days. Let it soak in. That may get rid of it. Did with me
Stuart
Hello Mate,
Just had it happen to mine, there are four courses of action, last one being the most expensive replacing the rubbers.
1. Autoglym rubber and vinyl care take the targas off spray all over the rubber seals targas and door seal leave them off and let it soak in!
2. Make sure the drain holes are actually letting water drain away down them.
3. Something I have not done is remove the rubbers on the roof where the targas sit and put a small amount of sealant under them
Hope the first one works for you!
Mark
Originally posted by MarkHanley:
3. Remove the rubbers on the roof where the targas sit and put a small amount of silicone sealant under them
Mark
Number three worked for me!!
Best of luck to you.
Robert
