KMH to MPH converter poll
If you have had, or currently have, one fitted please can you select an option and also post what make or supplier you got it from. Any details on failures also appreciated :)
Edited by Bartflaster
After fitting the converter, how did it perform ? 7 members have voted
  1. 1. After fitting the converter, how did it perform ?
    • Worked perfectly ever since fitting.
      57%
    • Worked OK to begin with then failed, either intermittently, or totally.
      42%
    • Never got it working at all.
      0%
      0
Came with the zed. Was done by a specialist near Aylesbury. Anybody want his number PM me
Had mine done at Zedworld :thumbup:
One small point - when you go over 100, the needle drops all the way back to zero then pings straight back to the correct speed (so I've been told). :whistling:
Also, its not much use below 20mph (so I've been told) :lol:
Is that a common thing ?
When I wired mine in it wouldn't read anything below 15mph either.
I could live with that, until it decided not to work at all today :confused:
I couldn't tell you, but I'd hazard a guess it was something do do with scaling up from km/h. 20km/h is nowt really, when you think about it - so there was probably little reason to have a speedo that was accurate to much less than that (although, if you're going to do a job, you may as well do it properly, eh?).
The 100mph thing is obviously some gremlin from the old speed restrictor, but its never bothered me - I don't really pay much attention to the speedo, unless I'm in a 30/40mph limit.
