yellow paint code?
As I understand it my pearl paint has a solid yellow paint code underneath then the pearl code is sprayed over it but what is the solid yellow paint code anyone?
I just checked what is listed for your motor, all the info I have is
YELLOW PEARL EH7
It doesn't list a separate base or effect coat, I would assume that is the colour coat they list. Maybe worth getting 1/2 litre mixed up and do a spray test.
YELLOW PEARL EH7
But remember that is proper paint codes. If you are just looking for touch up, then the code will most likely be different.
I know the pearl code but the car is sprayed with a solid yellow underneath its only the last coat that is pearl so I need that code and its for spraying not touch up
Does the EH7 get you the pearl then? Its the only one listed on the computer - I hoped it was the colour coat code, never mind.
Sorry I can't be of more help.
EH7 is the pearl colour that is the top coat but the car is sprayed with a solid yellow under this
Pretty sure the pearl is the basecoat then laquer over that. Normally with light colours and especially yellow a white primer is better to bring out the colour.
Ok it is primer yellow base coat not pearl then pearl coat them laquer I need the code for the base coat
Yours is not a three stage pearl its too early, they are only recently being used. The pearl is mixed in with the basecoat, so as Groover pointed out it is basecoat then clear. the clear coat will "bring out " the pearl effect.
Ok well in my engine bay and door shuts it is a solid yellow and after asking someone about this I was told that is how they did it so may have been a respray in there that was 3 stages
Might be worth going to a Nissan dealer with you vin number and see what they come up with, every source i have checked listing all colour codes state up to sept 91 EH7
No mention of any other code or colour, so either Nissan only sprayed the door shuts and engine bay in EH7 without the pearl added or its been resprayed.
Mine originally was pearl white, but under the bonnet is definitely not pearl, its just white lol and that hasnt been touched since it was made.
Exactly what I am saying the outside is eh7 pearl I know this however under that is a solid yellow which is in the engine bay and door shuts which is not eh7 and that from what I know and speaking to a certain person at at japfest is what is under the pearl paint which will be the basecoat which is what I'm after. No vin number is going to tell me what colour code that is hence asking on here
Your best bet is to take it to a paint supplier who has a scanner, they will be able to tell you exactly what has been used and the make up of the mix. My local supplier has one but your a bit far away. If its been painted it is the only way to find out what was used.
Had a look this morning and my vin plate has EM3 on it for the paint code?
I checked all the available 300ZX colour codes, and that one is not listed on the computer for some reason :headvswal
Deffo a job for the dealer or a colour test at a paint shop.
I even searched across the whole Nissan fleet, and that code doesn't show on any. Is it a special / one off by Nissan?
Lol thanks I remember trying to find it before and I couldnt I just don't know then what solid yellow codes do Nissan do as I had eh7 mixed up before and it seemed to light for mine however my thinking is with a solid yellow underneath it will make the pearl darker and therefore match mine
Understood completely. Take the EM3 code into a paint shop, ask to stick it in the machine and see what colour it gives out. Might be what you need....
Hold on a mo - just checked all Nissan yellows again. There is an EH3 "dark yellow".
Here is a list of every Nissan (all models / all years) that is in the system for the colour group yellow.
804 + 805 987 1988-1988
NISSAN BEIGE 10014 1993-1993
NISSAN BEIGE 10008 1993-1993
NISSAN BEIGE MET 117 1981-1981
NISSAN BUTTER YELLOW 119 1982-1989
NISSAN CALIFORNIA YELLOW 910 1970-1971
NISSAN COPPER MET 629 1979-1980
NISSAN CORN YELLOW D32 2002-2002
NISSAN CORN YELLOW Z37 2003-2011
NISSAN CREAM 685 1978-1979
NISSAN DARK BEIGE 535 1970-1970
NISSAN DARK YELLOW E01-51 1999-2000
NISSAN DARK YELLOW EH3 1989-1996
NISSAN DESERT YELLOW 804 1980-1985
NISSAN FUN YELLOW E10 2003-2006
NISSAN FUN YELLOW MAT E10 2004-2006
NISSAN GREYISH YELLOW 339 1984-1987
NISSAN IMPULSE YELLOW EV2 1999-2002
NISSAN IVORY 056 1985-1985
NISSAN IVORY 637 1969-1981
NISSAN LE MANS YELLOW 919 1970-1971
NISSAN LEMON 224 1973-1977
NISSAN LEMON YELLOW 179 1973-1973
NISSAN LEMON YELLOW 396 2002-2002
NISSAN LEMON YELLOW Z53 2003-2011
NISSAN LIGHT GOLD PEARL 042 1985-1992
NISSAN LIGHT GREYISH YELLOW PEARL MET EM1 1993-1999
NISSAN LIGHT LEAF 945 1971-1973
NISSAN LIGHT YELLOW E41 2005-2010
NISSAN LIGHT YELLOW EH2 1993-1999
NISSAN LIGHT YELLOW EW2 1999-2006
NISSAN LIME 650 1979-1979
NISSAN MELLOW YELLOW 102 1972-1977
NISSAN MOONSTONE YELLOW 433 1968-1969
NISSAN NEW ORANGE 008 E14YE008 2000-2000
NISSAN OCHRE 022 1972-1975
NISSAN OCHRE 967 1971-1972
NISSAN ORANGE 419 1978-2005
NISSAN PUMPKIN YELLOW 702 1988-1992
NISSAN SKYLINE YELLOW 950 1971-1972
NISSAN SOLAR YELLOW EW3 2000-2009
NISSAN SUN YELLOW MET D30 M9263 2005-2005
NISSAN SUNKIST YELLOW 665 1968-1973
NISSAN SUNSHINE YELLOW 016 1982-1986
NISSAN SUNSHINE YELLOW 019 1972-1975
NISSAN TAXI YELLOW 019 1995-1995
NISSAN TITANIA YELLOW 633 1968-1969
NISSAN TROPIC TAN 130 1983-1986
NISSAN URBAN YELLOW 964 1971-1972
NISSAN YELLOW 019
Im not sure but could you not get a flat non pearl yellow uk and i think specail order eh7 pearl as well . I went to a local automotive paint shop to respray a door mirror asked for eh7 and they gave me 3 cans 1 base yellow 1 whiteish pearl top coat and laquer .Not an exact match but not too bad .
