Where can I get.....
I'm looking for some of the 10mm bolts and the bits they go into that hold on the front bumper at the bottom, they are also found on other parts of the car.
I'm sure Nissan would have them but would rape me to get them.
Can anyone recommend anywhere that would do them cheap?
Thanks,
Daz.
Do you know what they would be called mate, there is shitloads of stuff to go through there?
The 10mm bolts are normally m6x1.00 with a 10mm head. Then just choose how long you want them. i.e. m6x1.00x20.
Metric bolt's can be a bit confusing. they are measured by the width of the shaft, not the size of spanner you need to undo them. Then you have the pitch which is measured in peaks per mm (1.00 = 1 peak per mil on the thread) 1.00 pitch is also reffered to as "course thread". Finally you have the lenght of the shaft, again measure in mm.
Edited by Steams
Thanks,
Daz.
If it,s the 10mm headed self tapping bolts your after they,re usually called Spire bolts and Spire clips are what they screw into.
Just found these so you know what i,m on about ! lol
http://www.ebay.co.uk/itm/10-mil-Acme-Wing-Bolts-and-Spire-Clips-Suits-Most-Cars-/250861696717?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a6885b6cd
That is the very things, cheers mate!
